Removing Side Repeaters On A Corolla E12
-T- Sport
Alrighty, as requested...
Start off by putting your index finger to the right side of the side repeater. Nearest the door of the car.
Once there, simply pull it towards the front of the car and it should click out.
The wires can be pulled out enough for you to take off the harness.
Finnished...
You can do whatever you want! Whether it be painting them, or simply changing the bulb. The bulbs inside are Orange 501s. :thumbsup:
Believe it or not...
Before I figured this out I actually spent 15 minutes removing two 10mm screwes and 6 Poppers. To get under the arch lining. Was only after re-fitting the first one it came to me that I could just pop it out... Idiot. :lol:
  • 1 year later...
  • 6 years later...
I've been able to remove the light from the wing but how do you remove the 2 wires from the harness? I don't want to just pull too hard in case i break the wire.
