This webpage uses Javascript to display some content.
Please enable Javascript in your browser and reload this page.
Welcome Guest ( Log In | Register )
2 Pages V  < 1 2
Reply to this topicStart new topic
> How To: Change Gearbox Oil, Pics from CTS but will apply to almost all FWD Toyotas
nrgizerbunny
post Sep 11 2009, 09:49 PM
Post #21
Top Rank Poster!
Group: Registered Member
Car Model:Corolla T sport
i'm glad some people found it useful.
Go to the top of the page
+Quote Post
nrgizerbunny
post Sep 11 2009, 09:53 PM
Post #22
Top Rank Poster!
i can't believe that toyota don't specify an interval for changing the gearbox fluid. it certainly makes a difference when its cold.and judging by the colour of the oil at 55k, it looks screwed.
+Quote Post
crxsud
post Sep 11 2009, 11:10 PM
Post #23
Club Member
Car Model:corolla
Great description
+Quote Post
nrgizerbunny
post Sep 13 2009, 07:27 AM
Post #24
Top Rank Poster!
what is everyone using in the gearboxes?
i've got the motul but would be keen to know what the other guys are using.
+Quote Post
djbenny1
post Sep 13 2009, 11:43 AM
Post #25
Club Member
Car Model:Corolla F/L T3
Hey would the gearbox oil being knackered cause my gear changes to be quite choppy when the car is cold?? 1.6 T3? Also would it cause my MPG to be low??? Cheers
+Quote Post
FoxX
post Sep 13 2009, 03:45 PM
Post #26
Club Member
Car Model:Corolla T Sport
QUOTE (nrgizerbunny @ Sep 13 2009, 08:27 AM) *
I ended up using the same as you because they were out of TAF-X, I looked around the local stores but the brands were all pretty weak and for the same price as the Motul.
I think this stuff takes a while to bed in, it certainly seems to be more efficient when its warmed up and it seems to have reduced some decelleration noise as I expected smile.gif but its still noticable through that aluminium gearbox shell. Next job - new clutch.
mmm by the way,
I dont think the gearbox oil would effect mpg too much unless it had no oil in it and had seized lol, but obviously less friction is good as its easier to turn smile.gif
+Quote Post
t_lew
post Oct 16 2009, 10:16 PM
Post #27
New Member
Car Model:corolla t sport
wheres the gearbox oil level plug?
+Quote Post
FoxX
post Oct 17 2009, 05:12 PM
Post #28
Club Member
QUOTE (t_lew @ Oct 16 2009, 11:16 PM) *
Hmm oil level plug?
You just make sure your car is on level ground, and fill it up via the fill plug until it starts to come out - then you know its at its maximum level. I think some Jags have disticks for the gearbox oil, but not Corolla's.
+Quote Post
nrgizerbunny
post Oct 17 2009, 08:19 PM
Post #29
Top Rank Poster!
WHS!
+Quote Post
the punisher
post Oct 26 2009, 09:32 AM
Post #30
Advanced Club Member
Car Model:CTS
I did this at the weekend.... 84k and no evidence its ever been done... WOW what a difference ohmy.gif gear change feels smooth deacceleration noise has been dramatically reduced.
i found a garden hose pipe was the ideal size for the refill, but the draw back is you can not see the oil in the pipe so i got a bit messy and i over filled it but it soon self leveled when i pulled out the pipe.
also i found the access to the plug on the front of the gear box was easier from underneth, but you do have to take off your scuttle panel but thats only four screws. Might be cos mine was preface lift but there was hardly enough room for my arm between the top of the engine and the radiator to get proper hold on doing and undoing the front plug.
Parts i ordered were spot on, and i used Castrol Transmission fulid.
I'd recomend this gearbox oil change to all corolla owners, seek professional help if your unsure about doing it yourself.
Joel
+Quote Post
myromeo
post Oct 26 2009, 11:13 AM
Post #31
QUOTE (the punisher @ Oct 26 2009, 10:32 AM) *
Joel,
how noisy was your box on decel? mine sounds terrible unless ive really thrashed it to warm the oil up!
Im off on holiday next week but when I return I plan on giving the whole car a major service, its not due but as im at 71k and only have what the service book tells me I think its not a bad idea.
Can I ask what oil people recommend for gearbox? also engine?
OP... superb writeup, many thanks! I was going to get Mr T to do this but after this writeup ill do it myself! CHEERS!
+Quote Post
kimi
post Oct 26 2009, 11:59 AM
Post #32
Top Rank Poster!
Group Icon
Group: Super Moderator
Car Model: Silvia S15 SpecR & Honda Integra DC5 TypeR
QUOTE (FoxX @ Sep 2 2009, 06:06 PM) *
Will one of the mods add this to Kimi's sticky how to's at the top you think?
+Quote Post
dzvini
post Nov 3 2009, 12:19 PM
Post #33
New Member
Car Model:Corolla TS '02
Guys, help me please!
I've just changed my gearbox oil on '02 TS with just 2L of Mobil mobilube SHC 75w90!
Do I have to fill it more or that is enough?
+Quote Post
Karma Supra
post Nov 3 2009, 12:35 PM
Post #34
Top Rank Poster!
Group: Advanced Members
Car Model:M3
Can I just add a little tip....
ALWAYS CRACK OFF THE FILLER NUT FIRST!!!!!!
A couple of you have already said it was a little stiffer to undo. If you find you can't get it off or a tool fails or something once you have already drained your gearbox, you are stuffed!
+Quote Post
FoxX
post Nov 3 2009, 06:27 PM
Post #35
Club Member
QUOTE (dzvini @ Nov 3 2009, 12:19 PM) *
Your 0.3 litres short there, I dont think it will be a major issue but i'd top up to be on the safe side to ensure the health of your gearbox. You can fill it on the flat without having to jack the car up again, but I guess you didnt want to buy another 1ltr bottle.
+Quote Post
nrgizerbunny
post Nov 3 2009, 07:46 PM
Post #36
Top Rank Poster!
i think karma supra's tip is a good one! the other one is a good dose of Penol the night before you do it.
2litres is not enough UNLESS you managed to leave 0.3l in the casing.
+Quote Post
dzvini
post Nov 4 2009, 01:45 AM
Post #37
New Member
Ok, tnx guys, I was in a local car service and they've filled only 2 liters sad.gif
I guess they where checking for some other smaller engines...
+Quote Post
Karma Supra
post Nov 4 2009, 02:40 PM
Post #38
Top Rank Poster!
Car Model:M3
The idea of the top up plug is you fill untill the oil runs out... Just make sure the car is level.
+Quote Post
2 Pages V  < 1 2
RSS Lo-Fi Version Time is now: 21st November 2009 - 11:06 PM
