Technical How-to Pages
Bibbs
  • 2 months later...
  • 6 months later...
SYNCRO's CRUNCHING?
Thanks for MR2OC, USA. For putting me on to this,
I thought our synchros was shot especially in 2nd gear.
Then found out you can adjust the engagement point of the clutch under the pedal
you can see in the picture where the adjustment point is.
you need a 12mm spanner, unlock the nut & turn the rod out till you can feel it against the master cyl, then lock the nut back up.
now it is so easy to get into & outof gear.
  • 9 months later...
  • 3 years later...
This topic is now closed to further replies.
