Wired Up The Lexus Lights
roywhlong
hi guys got all the bulbs holders and now ready to wired them up did any body know how to do it.ring kevin but he is away at the moment wont be back untill next week dont want to wait for so long just want to finish it up please some one tell me how to do it :help: and by the way my car is 2002 1.0 make in france not jap one :thumbsup:
you will need to cut the lights wires in half then extend them to the existing wires in the car
could do with some pics roy, or try and catch me up on MSN one night
yah rob that will be great because i still dont know to to wired them up and if you got a picture to show will be prefect it was alot easy and i am off today hope can get it done :thumbsup:
let me get this straight..
the lexus/altezza/eurolight/clear lights.. need special wiring.
is the "normal" (1.0,1.3l) lexus lights version is different then t-sports?
oh.. btw, are lexus lights are what jaxx have? or im completely in the wrong direction?
the lexus lights always drop straight on to the t-sport as its basically a rebadged vitz RS in most respect. most lexus lamps are designed for the vitz RS and being as they ahve the separate fog/reverse lamps then there is obviously a wiring difference on non-tsports
sooo if i have a t-sport.. ill have no problems with it?
oh.. btw jaxx.. u got under-car leds?
should just go straight on mate, mine took no more than 20mins to fit!
ive got neons at the mo, LEDs maybe in the near future
fit them in no problem but the problem is wired them up and try yesterday but still doesnt work and dont want to cut ant wire from the original socket and i know it was deferent on t-sport but just want to know what is all the color wires are
roy, i assume you have the pre-facelift yaris aswell?
i dont get it what is that mean ok will get a picture to show you what is the socket like and what i have to do about that
yeah.. i wanted to know also... what does it mean facelift?
is it the 2002 models and down that were before it?
the facelift or phase 2 yaris has the different style healamps with the teardrop or 'blob' as some people know it as at the bottom.
The t-sports from pre and post facelift also have completely different bumpers
now here is the picture
the back of the lexus light
and this is the back of original light
and another picture to show both lights on together
and this is the adaptor or socket what ever they call to connect with the original lights
so now rob are they same as the one on t-sport????
youve got the phase 2 style lights!
look on the lexus lights and the plug is part of one of the bulb holders
Kev from envy knows how to sort this however
he is away at the moment so i have no choice have to wait untill he is back :-(
OK, I am back now! :P Give me a call tomorrow sometime and I will talk you through it. :thumbsup:
HTH
Kevin
roywhlong
are you good at electronics, you need to cut some wires so you have 1 common earth and separte powers for each bulb, then extend those wires and crimp them on to the wires from the car
now try to wired them at today and the result is still not working :censor: and i blow the fuse twice as well can any body tell me all the color wires mean
1.green and back
2.green and white
3.black and white
5.green
7.red and white
i know black and white is (-) negative but the things is i have every work except the
please correct me if the connection i make on the picture is wrong
really just want this finish and took so long to try connected it up sound like a bit doh................!!!!!! :(
roy
the one you have circled in yellow is to be connected in a parallel circuit with the other brake/drive light
in original terms the yaris only has one brake/drive bulb, but the lexus style has 2 so you need to connect up the second bulb in the same places as the first one
its a bit harder than that red and white on one side of the car is the fogs, on the other side of the car its the reverse light,
both green wires go to the same green wires on the lights
middle wire is earth
and the one thats left is the indicator
still doesnt work here is the picture how to i connect it up so can any body got a picture to show me
can you guys tell me which one is has to connectted to green wire and which one has to be connectted with green and white wire
please :help::help::help::help:
you are not listening to me, you fuses will blow, there should only be one wire which links to all bulbs, the rest you will need to snip in half then extend them
