How To Reprogram Alarm/c-lock (yaris)
vmail
System operation
  • If vehicle unlocked and doors or boot/tailgate not opened within 30 seconds, locks/alarm are reactivated.
Programming
When
  • Key added or replaced.
  • System malfunction.
How
  • Driver’s door open and key removed from ignition switch.
  • Insert key into ignition switch, then remove it.
  • Within 40 seconds: Close and open drivers door twice.
  • Close drivers door.
  • Insert key into ignition switch.
  • Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program new key code whilst erasing the original codes.
  • Remove key.
  • System should now lock and unlock vehicle, once or twice depending which mode has been selected.
  • Carry out the following button procedure within 20 seconds:
  • Yaris built in Japan and Yaris Verso: Simultaneously press and hold key lock and unlock buttons for 1-1.5 seconds.
  • Yaris built in France: Press key lock button for a minimum of 1 second and release.
  • Within 3 seconds:
  • Press key lock button for a minimum of 1 second and release.
  • System should now lock and unlock vehicle.
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat button procedure.
  • If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Open driver’s door.
  • 5 months later...
no, just the yaris, which toyota are you after
Reprogram Alarm and/or c-lock, if it messes up, or you have a new key
to get this done by 3rd party could cost £40
  • 2 months later...
Would the procedure for an 02 plate Avensis Verso be similar by any chance?
Just got a new/second hand one and it only came with one master key, so thinking it might be a good idea to get a second, if I could program it myself it would be good, as the key costs about £60, and takes '3/4 hour to program' according to the Toyota garage...
  • 2 months later...
Hi, Im sorry to reply so late
I only have the info for the following
02 Avensis 1.6
02 Avensis 1.8
02 Avensis 2.0
02 Avensis 2.0 D4D
  • 5 years later...
Hi, Ive tried all the above I have a 2000 Yaris, I've done all mentioned however I just cant get the confirmation from the door locks? Ive tried everything but when I remove the key nothing happens?
  • 1 year later...
sorry to bump up such an old post but i have the same problem as the poster above.... i do not get any confirmation after a single ign on / off.
anyone been able to reprogramme a replacement key on the older type of yaris?
they have the rika tokai type chips.
