Rav4 New Model Rear Door Open Wide
paulmcmorran
I have the solution for the poor opening angle restriction of the rear doors on the post 2000 model ravs.
You cannot purchase this part from UK main dealers .This is a genuine Toyota part that can be retrofitted to allow the rear door to open to its full 90 degrees.
No longer does the door fall shut when parked on a slope and larger items can be easily loaded in the rear.
I have the parts in stock at £75 including postage.
It takes approx 15 minutes to fit for even the most modest of home mechanics.
Available also on eBay.
contact paulmcmorran@hotmail.com :yes:
Available also on ebay.
Firstly welcome to the TOC :) ,the guys did chat about this the other week
http://toyotaownersclub.com/forums/index.php?showtopic=25754
The part can be bought from UK main dealers if you have the part numbe,or as you say, get on off eBay.
Anyone know the price from UK Dealers?
When i quoted the USA part number 68650-42040 , the parts guy was gone for some time, and came back with a price of £56.85 + vat.
Got mine from sparkydog by return of post.
Most difficult and time consuming part of fitting is removal of trim. Once trim removed fitting of new part only takes 5 mins.
Door now opens to two positions, the first is same as original, second fully open. :)
  • 17 years later...
Hi I have a new 2021 RAV4 does anyone know if the brackets that allow the rear doors to open wider will also work on newer models
The topic refers to the tailgate - which on the Rav4s in question, were side-hinged. Eg:
The current Rav4's tailgate is different, being top hinged -
  • 11 months later...
Anyone know the part number for this rear door extended check strap for a Rav4 2006 (RAV-4 VVTI XT5), please? Or have a direct link to a part?
Thanks 🙏
