Dec 28 2004, 06:12 PM
Post
#1
New Member Group: Registered Member Posts: 2 Joined: 28-December 04 Member No.: 17037 Car Model:Tacoma Location:South Dakota |
All-
My trucks headlights are always on the High Beam position. The "regular" beams do not work at all, but when I flip it to "High beam", they both turn on. When I turn on the regular beam, the blue "high beam" light turns on and stays on. Is this a problem in the switch on the steering column? I checked the relay and had a new one installed. I also check for continuity in the headlighs and both of them work just fine. The probelm started to happen every once in a while, and now only the "high beams" work. I appologise if this is only as clear as mud, but I would really appreciate any help that you may have to offer. If you have questions regarding the problem, let me know and I will try to clear it up. Thanks, Ryan |
Lo-Fi Version | Time is now: 21st November 2009 - 02:43 PM |
