How To Reprogram Alarm/c-lock (corolla)
vmail
System operation
  • If vehicle unlocked and doors or boot/tailgate not opened within 30 seconds, locks/alarm are reactivated.
Programming
When
  • Key added or replaced.
  • System malfunction.
How
  • Driver’s door open and key removed from ignition switch.
  • Insert key into ignition switch, then remove it twice within 5 seconds.
  • Within 40 seconds: Close and open drivers door twice.
  • Insert key into ignition switch, then remove it.
  • Insert key into ignition switch.
  • Close drivers door.
  • Switch ignition ON and OFF once to program a new key code whilst retaining the original codes or twice to program a new key code whilst erasing the original codes.
  • Remove key.
  • System should now lock and unlock vehicle, once or twice depending which mode has been selected.
  • Carry out the following button procedure within 20 seconds:
  • Corolla built in Japan and Verso: Simultaneously press and hold key lock and unlock buttons for 1-1,5 seconds.
  • Corolla built in UK: Press key lock button for a minimum of 1 second and release.
  • Within 3 seconds: Press key lock button for a minimum of 1 second and release.
  • System should now lock and unlock vehicle.
NOTE: If system locks and unlocks vehicle twice, programming procedure has not been completed. Repeat button procedure.
  • If required repeat button procedure to program remaining keys.
NOTE: To exit programming mode: Open driver’s door.
hi,
you posted how to program a new key for a yaris on the forum, but do you have any guides for a 2002 corolla with standard c/locking
thanks
Hi, Ive PMed you and place the info you require here
This message can not be sent because the recipient does not have permission to use the personal messenger or their personal messenger inbox is full.
This personal message has not been sent
  • 1 year later...
I don't suppose you have the instructions for programming a key for a Corolla 1.6 GS 1999 (S plate). I tried these instructions and nothing happened.
Thanks,
K
  • 3 months later...
  • 1 year later...
Is this for any year Corolla?
Also, we have to press the Lock button twice for more than 1 second at a time?
Do we press the original key first and then the new key? or new key twice?
"Corolla built in UK: Press key lock button for a minimum of 1 second and release.
Within 3 seconds: Press key lock button for a minimum of 1 second and release. "
