Third Gear Grinds
cookci
simple problem really. sometimes it grinds when i try to change down and only down into third. it eventually goes in but takes a little persuasion. of course ive got my clutch flat to the floor. any ideas if this can be fixed and approx how much??
again... thanks for ur help ;)
Sounds like you need new syncro rings on 3rd gear. Needs a gearbox strip to do that (not a DIY job unless you're really, really brave).
You could try replacing the gearbox oil, if it's really old it won't be helping. Or just double de-clutch. :thumbsup:
I had the same problem on an old Corrado I used to have and once I got the gear linkages changed it sorted it out. In cars that have had either a replacement gear box or have a slightly lengthened gear linkage then that should sort the problem out. Unfortunately it is a garage job, unless you feel happy covered in gearbox oil. Good luck let us know how it goes.
:thumbsup:
change gearbox oil. DIY. may make it a little better.
other than that replaxe or rebuild.
worn synchro's mate - all celica's suffer (gens 4-6)
I've had similar problems - As said above it the syncromesh rings. I've been using Redline MTL for two years now and it's helped a lot. It's not cheap but it does the job.
i find 3/4 of the way down for clutch pedal helps me engage a stiff change , but at my age i dont have many. :lol::help:
sometimes i really cant get the f**ker in no matter how much a ram in :lol:
Gearbox oil has been changed 5000 miles ago and helped abit
looks like a might just live with it because a rebuild could be expensive right?
half way up the gearbox.same hole used for gearbox oil.
Ive got the same problem, mine crunches if i go from 5th to 3rd, have to got 5th to 4th then to 3rd or just miss 3rd completely. Thats only when driving hard though.
