What Speed Does You T Sport Idle At When Its Cold.
mark_n
After initial switch on revs at about 1500 rpm then backs down to around 600 .. usually within say 2 mins. I have had the idle rate in mine adjusted though
hmm dont normally have it go up that high. usually 1500rpm but sometimes does go higher
same as mine
in response to your title which is what speed does your t sport idle at:-
mine idles at 0 mph
mine idles at 0 mph
PMSL your the only one to answer his exact question
I can't get out of bed, but that's because I'm morbidly obese....
PMSL :lol:
Mine goes upto 2000 rpm for about 1 minute or so. Is this right?
So does mine, but soon drops down to 14/15 hundred and idles at 600 when at operational temperature.
Not sure what smaller engines would start up at.
I believe all modern toyota's do this.
Its a good thing, I haven't a clue why the likes of VW and other manufacturers don't do this, really.
You just turn your car on, from a stone-cold start. This means, the engine's oil is as cold as outside, and because its cold its thicker, and harder to pump around the engine (oil pathways are fairly small, etc)
So the revs are higher on cold starts to 1) promote the oil being pumped around harder (faster revs = oil pump spinning faster, so higher pressures) and 2) to get the engine warming up faster.
A few more revs won't generally hurt the engine when its cold, and when idle the engine isn't under any load (only has to lug its own moving parts around)
So, all-in-all don't worry about it. When your car is MOT'd, they'll check fast-idle speeds and the like and keep it in check, I guess it's also checked during services, although I'm not entirely sure
How come?? To suit the Chip?
Our TS idles at around 700RPM
Going upto 2000RPM is fine because the engine is cold (thats from Yves btw not me!)
Now i've got mine, I can say that its about 1500rpm too, and drops gradually down to normal idle speeds.
at the turn of the key it goes up to 1500 rpm, then goes down to 1000 rpm, then settles about 700 rpm
Then as soon as the blue light goes out, straight up to redline :lol:
i know...it should turn into a light that shows: GO GO GO!!!
haha
JK
That Blue light has to be one of the best gimmicks on the Yaris :thumbsup:
Blue = Slow... slow... and when it goes out quick... quick... GO!
:D
:D
you boy racer you...........
(dont expect a reply by the way :P)
