Nokia Ck-7w Kit On 04 Corolla
Jonathan Lynch
Could anyone tell me where to locate a power source to hook the phone kit up to in the corolla ?
I was rooting around behind the dash and noticed a free connector and a lot of cables to the airbag unit.
Does anyone know what this connector is for and if it can be used ?
Also I was wondering how to set up the mute facility to my radio. It says 58807 on the front of the radio and is
made by Matsushlta and has a model number of 86120-1A180
Photos of the radio: back, top and front
any help is appreciated
Jonathan
  • 4 weeks later...
here is all the info you need. For power you just have to connect the handsfree kit to the existing cables (12V, ACC, GROUND). If you have a CD Changer, it is the same for tel mute. if not, just connect somehow to the terminal at the headunit.
back
Just got that sorted. Bought a telemute cable by autoleads from carcommunications which allowed me to connect the radio power cables into the telemute box and then from the telemute box it provided a power connection for the phone kit and the lead to go into the back of the radio. Its a more expensive solution but is easier to fit.
It routes the sound of the car kit through the radio and also mutes the radio on incoming calls.
www.dashmount.co.uk do leads that i have used in both my yaris'
Plug and go, unplug the radio leads, plug the carkit in, plug the whole lot together and it mutes the radio, puts the sound through the Speakers and draws power without cutting a wire
