Gen 6 Headlight Seals
edamduke
Hey all,
I've fixed those so**ing seals around the outer headlamps. If your prepared to take the units out to do it you can do a good job of it and they should never come loose again.
I began by removing the bumper which was a bit tricky to get off. (make sure you have a bung ready (or a biro :lol: ) to block the headlamp washer jets) Then unbolt the headlamps, remove and clean up the rubbers and the lights.
I then put a beading of clear silicone sealant around the edge of the glass with intermittent gaps for hot melt glue gun glue to hold it instantaneously while the 48hr silicone dried. I also used the 4 metal clips to secure the rubber where possible. Put it all back together and it all worked a treat! :D
It's definitely worth it if you have the time.
Ben
Good Job , well done :D
or as i did just pull the rubber out , coat it in silicone sealant and put them back in ! saves a lot of f**king about tbh :)
exactly. super glue is as good as owt !!
if you go to that much bother, buy new rubbers and put all the clips back on
