Tns700 Gps Unit
Norwegian
Two questions:
Can you disable the disabling of functions while in motion?
Could you see how fast you are traveling? (digital km/h)
Two questions:
1e questions : yes you have to put a switch between the speedo cable towards the TNS 700
2e questions : NO
Two questions:
2e questions : NO
A switch - that simple? Can you elaborate at all for me - such as do you know the colour of the wire, what sort of switch, and how do you use the switch?
Sounds easy and worthwhile .....
Sorry mate , don,t now the color of your electronic speedo cable , but your local dealer could take a look in his Computer .
one thing when you use it the GPS is off course and it will take a few moments to find the GPS satelite,s again
Sort of sounds too simple to be true. Have you or anyone you know done it successfully? Doesn't the system use a GPS speed to track movement?
If this is the answer, there are a lot of people who are going to be buying a lot of switches!
Just wanted to say a BIG THANK YOU to G6-R. I did this today and it's so simple and works just fine. You should spread the word about this one as it has just saved me a whole load of headaches!
Thanks matey
Thanks matey
Youre welcome mate ;)
  • 2 months later...
Two questions:
2e questions : NO
I found out that you actually can see a digital km/h. Its hidden in the diagnosis menu B)
Two questions:
2e questions : NO
How do you access that menu??
Hold the Info button and switch your lights on/off three times.
Press and hold the Info button to get out of it.
Thanks for that ..... :)
Two questions:
Yes you can do that with a switch between the pulsecable of the speedo and no you can,t see how fast you are driving
You're wrong (see above replies).
A digital km/h is shown in the diagnosis menu although this is a very inconvenient way of displaying it.
Excuse me :o i don,t use that thing but only for navigation :P
