May 21 2009, 12:27 PM
Post
#1
![]() Top Rank Poster! ![]() Group: TOC Supporter Plus Posts: 1838 Joined: 3-June 07 From: West London Member No.: 40784 Car Model:Corolla T-Sport Location:West London |
I have an unused celica 140 flywheel for sale, it will fit the MR2 1.8 or Celica 1.8 (140bhp) 1zz-fe engines. I bought the flywheel for 240 and got the part number wrong and cannot return it now as i left it to late to fit with my clutch system. So ran out of the returns policy.
This is a bargain for someone so grab it while you can, Im based in west london i beleive it will the avensis 1.8, If buying this product you probably know what a lightweight flywheel does but if not ill post the manufacturers description. This Fidanza flywheel weighs 8.5 lbs making it the lightest 1ZZ flywheel available. You can expect a noticeable improvement in acceleration especially in the lower gears and heel-toe downshifting is much easier thanks to much livelier throttle response. Slightly more throttle is needed to pull away from a stop without stalling though most people get used to it and like the sportier feel. Fidanza Flywheels are made using the highest quality and most modern materials available. The flywheel itself is made from either 6061 T6 or 2024 T3 aluminum depending on the model. Both of these materials are tempered aluminum which are very strong yet very light weight. The friction surface is very special. Fidanza uses a 1050 high carbon, alloy steel. It is incredibly durable allowing the use of just about any clutch disc material available from organic to Kevlar and even sintered iron. Fidanza attaches the friction surface using aerospace nuts and bolts. These are some of the best fasteners money can buy. They choose them because of the incredible shear strength and resistance to corrosion. All Fidanza ring gears are heat treated for durability. They are heated, pressed on and then secured using grade 10 fasteners. Part no:130231Asking Price is £200 but i am open to reasonable offers. Please PM me to discuss |
Jun 9 2009, 01:39 PM
Post
#2
New Member Group: Registered Member Posts: 4 Joined: 18-July 08 Member No.: 62779 Car Model:MR2 Roadster V6 Location:Sutton , Surrey |
PM sent if you still want to sell it.
Lo-Fi Version | Time is now: 21st November 2009 - 04:08 PM |
