When i removed this part of the CAF my mpg rose dramatically without anything else being done to the car or changing how I drive it. It does however cause a slight drone around 1800rpm. When the car was brand new it managed 35mpg (iirc) at an indicated 75mph. This rose to around 39mpg with age. Last week it did 44mpg at 75mph and 2 days ago it was showing 45mpg when I got to London, much better than last time when I got 39mpg.
However I am not saying this will work for you, maybe something else has happened to my car during the night but its worked for me
I did this whilst I had all the plastics off so I could fit new bulbs which made access much easier but I think you could probably do it in situ or by only removing the battery cover.
How it comes as standard
The part you remove
And how mine is now
This has resulted in the cold air not being brought round a tight 90 degree bend and it isnt pointing backwards anymore! And I've driven it through awful awful rain and it hasnt got wet inside the pipe yet!
Cheers
John
MultiQuote
