Help - Search - Members - Calendar
Full Version: Rav 4 Intermittent Power Loss
Toyota Owners Club - Toyota Forum > Toyota Forums > Rav 4 Club
porkie24
Hi, I have a RAV4 and have been getting problems with lack of power mainly from 3rd gear up but at any revs!
had it diagnosed at a local garage near work and the report was the fuel pump should be operating around 900 / 1250psi ( I think its psi ) but when the power is lacking its only doing 250psi. I was wondering if anyone else had experienced such a problem or it may be something else as a new pump is in exess of £800!!!!!!!
I've looked at a few other threads and some were talking about replacing SCV?
Can anyone advise?
Regards Paul
Oh b.t.w its a RAV4 2.0 D4D 2001 and the error code was P1228
anchorman
All my info is pointing to the SCVs for that code and the symptoms are typical. It cures a high percentage but no guarantees. Kingo will post them to you at a discounted rate.
a7peh
[quote name='porkie24' post='943791' date='Nov 11 2009, 08:29 PM']Hi, I have a RAV4 and have been getting problems with lack of power mainly from 3rd gear up but at any revs!
Can anyone advise?
Regards Paul
Oh b.t.w its a RAV4 2.0 D4D 2001 and the error code was P1228[/quote]
Hi Paul,
I have just taken my SCV's out and put them back in after a week and the car has returned to normal. I bought some second hand ones on E-bay and put them in for a week and the car was worse than before, permanently in limp mode. The original valves may have had some residue on them when I took them out, I am not certain, but anyway the engine is now running perfect. Perhaps you could try the same, just take them out, give them a bath in clean diesel and a blow dry and put them back in again. I would be interested to see if you had the same result.
Regards, Peter.
P.S. you need a decent 5mm. allen key and the patience of Job to do the job. Second time round it is a doddle
Ravmania
Is it still running okay on the original SCVs?
Cheers,
Pete.
a7peh
:drool: My rav4 d4d 2005, is still running fine on the original scv's. I did have a blip when I towed my trailer to the skip, it started acting up again, but as soon as I unhitched the trailer the car was back to normal. Perhaps the extra loading of the trailer caused the problem?
Peter.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
