No blog for two weeks.. Last Wednesday installed turbo, cam belt, injectors, charger brushes, charger belt, commonrail.
Today, valve cover, injector tubes, oil sump, oil pan. That means, the engine is now whole.
Jacked engine down, on a board on rollers and moved it.
Next it is time to lift the nose of the car up again, roll the engine under, lower the nose down and mount the engine.
Still the rear mount problem unsolved..
[url="http://toyotaownersclub.com/forums/index.php?automodule=blog&blogid=92&showentry=439"]http://toyotaownersclub.com/forums/index.p...p;showentry=439[/url]
