Hi all I have a BRAND NEW Apexi S-AFC2 for sale
Bought 1 week ago but have since invested into a Apexi Power FC so need to rid of this.
Never fitted still have box and every thing.
The Apexi S-AFC2 is universal, and fits 99% of most JAP cars.
If you are looking for product documentation, click here.
This is the latest model
Looking for about £240 including recorded P+P in the UK
Below is title description from Apexi website...
DIGITAL SUPER AFC
Piggyback Fuel Computer
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
The second-generation S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is +/- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Due to the complex
