Help - Search - Members - Calendar
Full Version: Security Code After Drained Battery
Toyota Owners Club - Toyota Forum > Toyota Workshop > Workshop Submissions
TurboGT
Hi, I have a 1992 toyota celice GT with the double stack stereo CD and Tape original from the factory. My battery recently failed and I have a display that reads "code"on my stereo now. How may I clear this. What is the code? How many numbers might it consist of?
Any help would be great.
Thank you!!
Mick24
Try the last 4 digits of the VIN/Chassis number - hopefully the previous owner
has'nt changed it.
TurboGT
So what do I try?
Do I turn on the car and just press in the code on the buttons?
GT4 BOOSTER
take the serial number of the unit to toyota , prove the car is yours and for a small fee , they will give you the code and tell you how to do it. :thumbsup:
deekay140
there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.
chrisf127
i just recently got the code for my stereo for free
ring up the number that deals with the stereo
fax your details to them of the year and that
and they send u a fax back with different codes.
well imagine it is the same as i contacted sony
hope it helps
stand_fast
[quote name='deekay140' date='Oct 22 2004, 02:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.
[right][snapback]230249[/snapback][/right]
[/quote]
Could you help me out with a radio code. My deck number is 11708 from a 94 Toyota Camry.
Thanks in advance
tudorick
[quote name='deekay140' post='230249' date='Oct 22 2004, 09:57 PM']
[/quote]
I have a 4-runner and need the security code. The model is 34224.
Thanks for your help.
johnnyx
[quote name='stand_fast' post='378205' date='Jun 28 2005, 09:47 PM']
[/quote]
Could you help me out with a radio code. My deck number is 16804 from a 94 Toyota Supra serial# 0100822.
Thanks in advance deathangel-85@hotmail.com
[/quote]
Lu1
[quote name='deekay140' post='230249' date='Oct 22 2004, 09:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
Hi
I saw this answer and I have the same problem No code. We bought a 1995 Toyota Camry and replaced the battery.
Can you help ?
There's 2 numbers on the front panel...don't know which one you need
L4200
A11712
kubeq83
[quote name='deekay140' post='230249' date='Oct 22 2004, 10:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
Could you help me out with a radio code. My deck number is 11708 from a 94 Toyota celica gt .
Thanks in advance
omerta
[quote name='deekay140' post='230249' date='Oct 22 2004, 02:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
THE NUMBER IS-34210
amn8421
[quote name='deekay140' post='230249' date='Oct 22 2004, 01:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
Hi, having the same issue with security code after changing the battery. Looking for the security code for
Radio Model # 51706 for 1997 Toyota 4Runner. Thanks for your help!
mjtanaka
can you send the procedure to enter security code for 1996 toyota 4runner - radio code 51706
geegee
I have the same issue for my 2006 Camry. Radio no. is 17825. Any help would be massively appreciated
Thanks all
forevertech
Guys,
I have a toyota Echo 2000 model,
battery went flat this morning, replaced it, and radio says sec.
It says Toyota 32801 on the front of the radio
Cheers
ToyotaOwner08
Two days before Holidays start & I cant use tape/radio due to "SEC". This happened after I changed my drained battery. I have tried 8 times :(
I have tried last three digits of VIN as well but no luck. Please help.
The radio deck # A11713
1997 Camry V6 LE
Betho
Help me i got an A11712 got SEC on display, code and the procedure please.
Betho
Tagit
[quote name='Betho' post='837446' date='Jan 2 2009, 11:34 PM'][quote name='deekay140' post='230249' date='Oct 22 2004, 10:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
[/quote]
I have nothing being displayed after changing out the battery and ALT fuse (bear). Now the radio is dead, nothing displayed on LED. Fuse looks good.
Do I need a code? The number on the front of the radio is 74104.
Thanks if there's help out there for the 1998 Camry
Tagit
Is this thread active? Just wondering. Still trying to help my wife by fixing her radio.
mtfere1
[quote name='deekay140' post='230249' date='Oct 22 2004, 04:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
I have a used 07 RAV4, and need the security code. number on radio is 11812.
chinax_pac
The five digit number are 34224, would be most grateful to solution finder. Any other relevant information pls reach me on chinax_pac@yahoo.com. |My car stereo shows SEC
littlelisa
Please can someone help....i have a toyota avensis 2000 i need the code for my radio which hasnt worked since my battery shorted...im hoping i just need to insert the code, but i cant find it. can someone tell me the code and the procedure in order to install the code. the model number on the front of the radio is W53804
Wycom
[quote name='Tagit' post='837589' date='Jan 4 2009, 04:05 AM'][quote name='Betho' post='837446' date='Jan 2 2009, 11:34 PM'][quote name='deekay140' post='230249' date='Oct 22 2004, 10:57 PM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
[/quote]
[/quote]
Have same issue with our 2002 Echo. Radio showing sec after battery replaced. Number on front of radio is 37409. Can anyone help"
Nayncruiser
[quote name='deekay140' post='230249' date='Oct 23 2004, 08:57 AM']there is a 5 or 6 digit number on the front of the radio, post it up and I'll get you the code, and send you a copy of the procedure.[/quote]
Please if someone could help with a code and procedure would be fantastic.. The 5 digit number on the front is 34224.
Its from an 80 series Landcruiser. Thanx so much. My email is timandreneeryan@bigpond.com
Tavphoto
any help please with a 1994 'M'' Reg Previa radio 13705, that has gone into 'secuity code mode' after a dealer replaced the battery, I don't have any codes
Trevor
Hercules
Hi - Have the same problem - Toyota Camry 1992 - No on radio is 37411 - Thanks for your help
tallyben
Same problem...my number is 51703. It's a 1993 Camry V6 LE Thanks
wayneB
I have a 1994 Camry Vienta V6 CS-X with a Fujitsu Ten radio cassett that is showing SEC. I don't have the code as I bought the car second hand. The owners handbook says to hold down the 1 & 3 keys with the Pwr/Vol button pressed and wait untill sec comes up. Mine seems to be locked up displaying Sec all the time. Can you tell me how to get code and how to reset radio. Thanks
wayneB
:angry: :angry: [quote name='wayneB' post='892458' date='May 20 2009, 05:39 PM']I have a 1994 Camry Vienta V6 CS-X with a Fujitsu Ten radio cassett that is showing SEC. I don't have the code as I bought the car second hand. The owners handbook says to hold down the 1 & 3 keys with the Pwr/Vol button pressed and wait untill sec comes up. Mine seems to be locked up displaying Sec all the time. Can you tell me how to get code and how to reset radio. Thanks[/quote]
:angry: :angry: :angry:
I GUESS THIS SITE IS NO LONGER ACTIVE OR THAT OUR QUESTIONS ARE NOT IMPORTANT ENOUGH. GOOD ON YA'S............
big jake
hi i have 03 sinna radio ddead after battery replacement fuses good do i need a code to unlock it radio number on front
16814 its a fujitsu 10 ser#m8903418 an the procedure to do it
91 LANDCRUISER
DEEKAY I HAVE A 91 LANDCRUISER , REPLACED BATTERY AND GOT SEC. NUMBER ON STEREO IS 56803. WOULD APPRECIATE IF YOU COULD GET ME THE CODE. THANKS
bighead
[quote name='stand_fast' date='28 June 2005 - 03:47 PM' timestamp='1119995258' post='378205']
[/quote]
Thanks in advance
[/quote]
bighead
[quote name='deekay140' date='22 October 2004 - 03:57 PM' timestamp='1098482223' post='230249']
[/quote]
bighead
I have a 1994 celica with stereo #16804. Just recently purchased & had to change battery. Well, radio stopped working with a sec in the display. Do you know the sec code and how to input into stereo to get working again?
Any help would be greatly appreciated!
Thanks.
kkaahir
[quote name='deekay140' date='23 October 2004 - 07:57 AM' timestamp='1098482223' post='230249']
[/quote]
Hi deekay,my radio number is 32804 ,can you get me the code. thank you.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
