QUOTE (hochness @ Jun 13 2003, 05:02 AM)
Hello, I am new here and was just wondering if anyone would be able to help me out???
I love my 4Runner and am pleased with it except for this little problem.....
If I drive for a little bit at about 65 and up the a/t oil temp light will come on and not go off till I shut down the truck and let it sit for 15 min.
I've been told that this is just a problem that Toyota had/has with early 4Runners. They said that these trucks were not meant to be driving on long distances????
Is this true and what can be done to remedy this problem?
Thanks for any help in advance.
Sam
hello Sam
both engine's and A/T's fluids themp have been designed/calculated by the Brand and it is never mind what distance/time under way is covered.
So , in case you ve an A/T fluid themp issue then it must be investigated, as follows:
- cleanliness of themp sensor of an A/T;
- cleanliness of an A/T fluid cooler (it must be normally coolled by an engine coolant);
- normal engine coolant working themp and warranty that the respective coolant themp sensor gives correct readings (!!!)
- good performance of an A/T fluid circulating pump (if any available)
- cleanliness of the engine coolant fore radiator ribs;
- good performance of the cooling fan/s (!)
Be focused on the A/T fluid cooler (heat exchanger) first
Good Luck/Igor
