Heres my problem
I have a 94 CarinaE 1.6 GLi, I recently developed a problem with my ABS Breaks, the warning light came on to indicate a problem, as I don't have much care for the Toyota Dealers (as they Don't seem to want to fix any problems - and replace perfectly working parts at the cost to me) I prefer to work on the car my-self (Novice/Beginner), I just wondering if anyone could suggest a solution before I take it to a private mechanic.
This is what is occuring - The ABS Light (On Dashboard) goes on & off at random intervals, when the light is on the breaks works fine, with no problems, however when the light goes off the breaks stop working and I can hear something shutting down (ABS Breaks) and if the breaks are pressed when the light is off, it makes a scraping noise - with vibrations occuring in the actual break pedal. My breaks have also been squeling since the problem arose.
Basically I have, checked & Bled the breaks to rule out any air being in the system, this hasn't been the source of the problem. A friend suggested that it maybe a problrm with the sensors, but that doesn't explain the breaks failing. Also the CODE given from the error, says to check "Vacuum Sensor Signal" Code 31. i have no idea
I hope I was clear about problem
if anyone can help, it will be much appreciated.
James
