I've had my 'rolla lowered by 30 mm on TTE springs, and I know I've got to get the aligning sorted out.
With that in mind I rang a chap up in Stevenage, and after telling my story he said I'd have to get the camber re-adjusted professionally by some chap in North London, otherwise the settings would never be correct.
Is this advice sound? Afaik I had to do the alignment only, and if I'm feeling generous do the balancing as well, but camber as well?
If so this is not as easy as I had imagined.... or are the chaps that lower their chariots hoofing around with incorrect camber settings?
