Galee
October 25, 2005, 8:24 pm
Hi all long time since I have been on here have been over at the Lexus forums for a while! I have just had a 1994 MR2 Turbo come in but the turbo is not working at all it does not smoke and drives fine it is a genuine turbo as it has the turbo and raised bootlid and turbo dash. What is the first port of call of checking what could be the problem? Anyone with any advise would be greatly received.
Regards
Galee
jaxx
October 25, 2005, 8:26 pm
pull off the intake pipe and check for play or movement in the shaft, or indeed if its stuck!?
Galee
October 25, 2005, 8:38 pm
will try that in the morning and report back is there anything else I can check after that?
Regards
Galee
toystar
October 26, 2005, 7:50 am
Is it boosting or even trying too check the attuwaiter on the turbo its got a round cylinder shape at one end with a pipe on it and a piece of bar about 2 1/2 inchs long on the other this then connets to the waste gate. Check it is still conneted ive known the tiny clip to break before Then check the pipes are all conneted with no kinks in them. It may be that the turbo is working just running very low or no boost at all have you got a boost gauge???????
3S service centre
October 26, 2005, 2:19 pm
if you want to call me on this i can help diagnose the problem when your next to the car
James
07881942241
boundsw
October 26, 2005, 5:12 pm
do you get any boost
do you get any spool up
no spool might be blown impeler of the shaft (knakered turbo!!)
spool but no boost might be wastegate jamed open, autuator really soft, split pipe work etc, prob not so seriouse !!
Galee
October 27, 2005, 4:17 pm
Hi guys thanks for all the replys and help. I have taken off the intake pipe and put my fingers in there and I can fell the turbine wheel(Which I take is attached to the shaft) which was stuck I tryed moving it back and forth and it did free off to about a quarter of a turn should this wheel run freely all the way round? If so could it be freed off or will it be A new turbo something more sinister? If it is a turbo whould this be any good for it
[url="http://cgi.ebay.co.uk/TOYOTA-CT26-TURBOCHARGER-ACTUATOR-SUPRA-MR2-TURBO_W0QQitemZ8009839411QQcategoryZ72205QQrdZ1QQcmdZViewItem"]http://cgi.ebay.co.uk/TOYOTA-CT26-TURBOCHA...1QQcmdZViewItem[/url]
BTW The car does have a boast gauge the factory one located in the center of the speedo.
The turbo boast gauge has never moved since it come in.
Regards
Galee
jaxx
October 27, 2005, 4:53 pm
should spin without effort and no liner or radial play
TOYMOTA
October 27, 2005, 5:29 pm
Sounds like what happend to mine mate. The exhaust propeller destroyed itself and all the bits of it ended up in the CAT.
I'm 95% sure you'll need to get it reconditioned or get a new one.
That ebay one looks like it's had a hard life. The 2nd hand one I found was clean as a whistle at the exhauts end of it, not all black like that one. Any turbo you buy, you'd be best to have a good look at before buying. If there is any play in the shaft (do either of the props wiggle about) steer clear as it will soon blow up itself. There's normally always someone selling one on the MR2OC. I got mine for £120, which is a goodish price for a 2nd hand one IMO. Good luck!
This is what my broken one looked like:
[img]http://img.photobucket.com/albums/v251/TOYMOTA/DSC01500.jpg[/img]
Notice anything missing???
jaxx
October 27, 2005, 5:42 pm
FLIPPIN HECK
isnt there meant to be some spikey looking thing in there
Galee
October 28, 2005, 7:48 am
Thanks for the info guys I shall take my turbo off and try and get another I have found 1993 MR2 turbo being broke would the turbo from that fit to my 1994?
Galee
TOYMOTA
October 28, 2005, 11:22 am
Jaxx: A spikey thing?? Do you mean the exhaust propeller??
Galee: CT2Ob?? Yes it will go straight on!!
jaxx
October 28, 2005, 11:46 am
its jaxx.... and yes
it was sarcasm..
TOYMOTA
October 28, 2005, 12:43 pm
[quote name='jaxx' date='Oct 28 2005, 11:46 AM']its jaxx.... and yes
it was sarcasm..
[right][snapback]444454[/snapback][/right]
[/quote]
Sorry mate, it was stupidity on my part. Edited it now!!
Galee
October 28, 2005, 3:47 pm
Right have started to remove my turbo but am now stuck I have removed nealy all pipes apart from the one on the bottom of the turbo and it is still stuck solid and it does not look like the back of the one posted by toymota. I have removed a clamp (photoed) can the turbo be split here or do I need to unbolt the manifold and take the 4 bolts under there? I have included some photos that might help explain[url="http://uk.pg.photos.yahoo.com/ph/ggirdlestone/album?.dir=ebe2"]My Webpage[/url]
Regards
Galee
jaxx
October 28, 2005, 7:03 pm
theres a bracket underneath if youve not got that?
ive got the repair manual in PDF but cant extract JUST the turbo bit as its password protected
will see if i can upload it
Galee
October 31, 2005, 7:34 pm
Turbo all off now need to get some gaskets any one know where?
jaxx
October 31, 2005, 8:49 pm
toyotas the best bet
youll need the chassis/frame codes and all that though
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
