QUOTE(Bibbs @ Dec 13 2005, 08:52 AM)
QUOTE(Gregg @ Dec 12 2005, 10:54 PM)
forgive my ignorance, but would these fit a toyota avensis 1999?
[right][snapback]467135[/snapback][/right]
You'd need to check the PCD/stud pattern ..
114.3 x 5 ..
[right][snapback]467216[/snapback][/right]
Has bibbs says if your stud pattern is a 5 stud, 114 PCD then yes you should not have any problems. You can measure this yourself.......
Measure from the center of the hub to the center of one of the studs. It should be around 57mm.
Regards
Lee
