Help - Search - Members - Calendar
Full Version: Help - Fan Belt Tension
Toyota Owners Club - Toyota Forum > Toyota Forums > MR2 Club
Bobby-H
My fan belt has started making a bit of a noise when I have everything switched on so I'm going to change it.
I dont have a guage to check the tension on the new belt so whats the best alternative method to check it (I dont want to over do it and brake the barings on the alternator).
On other cars I've I could usually check the maximum amount of movement in the middle of the belt, but what should the maximum amount be on this engine?
Tegan
Might be worth having a look on some of the stickys at the top of the page - they have useful tips from people who have been there and done it :)
or just found this simlar topic on imoc :
[url="http://www.imoc.co.uk/forums/viewtopic.php?t=25427&highlight=fan+belt"]Alternator belt[/url]
Might help :thumbsup:
Boro Sera
General rule of thumb here is to fit the belt, then take hold of it at the middle of the longest side between the pulleys and twist it sideways. You should be able to get 1/4 of a turn on the belt. Less and it's far too tight, more and it's slack . It's not exact, but it does the job.
Bobby-H
[quote name='Boro Sera' date='Dec 30 2005, 11:45 PM']General rule of thumb here is to fit the belt, then take hold of it at the middle of the longest side between the pulleys and twist it sideways. You should be able to get 1/4  of a turn on the belt. Less and it's far too tight, more and it's slack . It's not exact, but it does the job.
[right][snapback]475267[/snapback][/right]
[/quote]
Great, cheers.
quigonjay
[quote name='Bobby-H' date='Dec 27 2005, 11:50 AM']My fan belt has started making a bit of a noise when I have everything switched on so I'm going to change it.
[right][snapback]473715[/snapback][/right]
[/quote]
the mr2 has no fan belt :P
Bobby-H
[quote name='quigonjay' date='Jan 3 2006, 08:36 PM'][quote name='Bobby-H' date='Dec 27 2005, 11:50 AM']My fan belt has started making a bit of a noise when I have everything switched on so I'm going to change it.
[/quote]
[right][snapback]477293[/snapback][/right]
[/quote]
Ah, yes, perhaps i should have said alternator belt or auxiliary drive belt :P
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
