QUOTE(mcsky @ Apr 14 2006, 08:43 AM) [snapback]526509[/snapback]
ah ryt, my Pi ones i have on now are also 40mm all round, was just wonderin if its those adjustable ones. want mine to go lower even more, looks great when the 15's sink into the arch. i might just fill my car with a heavy load of junk lolz and weigh it down, and go cruise in this nice sunny weather lolz, today that is, very nice sunshine here up north
Na you want the arches to be snug to the wheel but so you can still see the edge of the tyre so it frames it
Hiding them in the arches just looks rude boi chav!
i reckon 40mm should be plenty on 15"! Mayb consider getting 16" if you want it to look better round the arches. Also wouldn't buying aftermarket shocks help a bit as aren't they shorter so lower a bit? However they would reduce the amount the wheel hide in the arches when the load increases as they're stiffer. Swings and roundabouts.
