SH-PG1 Pearly gates. Neck position.
4 conductor wiring, for series or parallel options. Currently wired in series. Roughly 13 inches of wire from baseplate to end.
Designed around the original 59 Les paul PAF's with a nice bluesy tone. Sounds cracking through overdrive.
Pic :
SH-8 Invader. Bridge position.
This is a high output pickup designed for metal tones. It has huge black oxide pole pieces caps and looks the part. Also has 4 conductor wiring, and is currently wired in series. Very fat sounding, will have tears running down your leg when you crank up through the classic 'scooped V' setting.
Roughly 9.5 inches of cable from baseplate to end.
Pic:
Both pickups were put in my guitar just under 9 years ago. They're both in excellent condition, bit of dust on them, but otherwise sound excellent.
Original retail prices were 89 quid each, although these days the Pearly is 77 and the Invader is about 64.
Looking for 80 quid for the pair of them, or will split for 40 each.
Sound clips and full stats available here:
Seymour Duncan site
