S.Kayani
May 9, 2007, 4:16 pm
Hi guys, bit of a long shot but - i was wondering if you guys could help me, im making a project at college where i have to make a system on excel
and i really need your help!!!
basically i need to know a code for an OK button for a userform so that when data is entered into a user form, it gets added to the next row in the list on a spreadsheet - the current code i have is
Range(col_Pos + "A34") = NewProductsForm.TextBox1.Value
Range(col_Pos + "B34") = NewProductsForm.TextBox2.Value
as you can see when ok is pressed the data will go to A34 and B34
basically i need to know a code so that the next time data is entered it will go to the next free row, e.g A35 and B35 then A36 then B36 etc - onwards... (if the cells above are in use)
hope you understand what i mean!!
and thanks ALOT!!
Moffmo
May 9, 2007, 5:09 pm
what does col_Pos do?
Can you do it so you can add a string and a integer together?
eg.
Range(A + int);
This way all you have to do is int = int + 1
Not done visual basic in absolutely ages so dont know what you can do with it
vmail
May 9, 2007, 6:41 pm
I'm not a VBA expert, but col_Pos looks like a variable
Why not store the data in an array, then simply add the new data at the next free location
S.Kayani
May 9, 2007, 6:56 pm
cheers ill try that, think it stands for column position
any other ideas?
vmail
May 9, 2007, 7:00 pm
It a bit difficult to say without seeing the full code
do you have something like
"Dim Col_pos As Long"
It could stand for column position, depends on who originally wrote the code, I dont see any comments
Boro Sera
May 9, 2007, 10:12 pm
I was thinking 'Column Position' too.
There are loads of tips for VB/Excel coding in the link below
[url="http://www.angelfire.com/biz7/julian_s/julian/julians_macros.htm"]>>click me........you know you want to<<[/url]
If you're still stuck then shout up !
Rich
S.Kayani
May 10, 2007, 3:48 pm
thanks alot for your replys guys!! seriously appreciate it!! this needs to be handed in tomorrow so i need to get this working so i can get some of the other stuff done
[url="http://www.putfile.com/pic.php?img=5423578"][img]http://img2.putfile.com/thumb/5/12911455148.jpg[/img][/url]
this screen shows the form and where the information should go, basically i need a code so that when ok is clicked the new data wont just go to cell A34 and B34 next time something it added i need it to go to the next free cells
and heres a print screen of the original code
[url="http://www.putfile.com/pic.php?img=5423579"][img]http://img2.putfile.com/thumb/5/12911455145.jpg[/img][/url]
Boro Sera
May 10, 2007, 5:46 pm
the easiest way is something like this ........
Set a counter out of the way and +1 to it every time an item is added.
( it would be helpful to declare this as a variable rather than just reading the range. it'll make things a whole lot easier. We'll call this variable Roger for this example ! )
Then, instead of saying
[quote]Range(col_Pos + "A34") = NewProductsForm.TextBox1.Value
[/quote]
use the code A&Roger instead of A34, B&Roger instead of B34.
on the CommandButton1.click subroutine add a line saying Roger = Roger+1
it's a basic way of doing it ( no pun intended ), but perfectly acceptable.
Good luck !"
Rich
Don't forget !
Declare Roger as a public variable and you can stash the counter anywhere on any form !
S.Kayani
May 10, 2007, 5:47 pm
thanks alot for your help matey!!
managed to get it sorted!
the code used was
Private Sub CommandButton1_Click()
Dim LastRow As Long
If WorksheetFunction.CountA(Cells) > 0 Then
'Search for any entry, by searching backwards by Rows.
LastRow = Cells.Find(What:="*", After:=[A1], _
SearchOrder:=xlByRows, _
SearchDirection:=xlPrevious).Row
LastRow = LastRow + 1
End If
Range("A" & LastRow) = NewProductsForm.TextBox1.Value
Range("B" & LastRow) = NewProductsForm.TextBox2.Value
NewProductsForm.Hide
Unload Me
End Sub
Boro Sera
May 10, 2007, 5:49 pm
easy !
Nice one mate.
S.Kayani
May 10, 2007, 5:56 pm
thanks again to every one who helped!
(can be closed if needed)
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
