It has:
Built in TV (comes with TV antenna)
DVD player (Can be viewed whilst driving - but its for passengers
Handsfree Bluetooth (works with any bluetooth phone - built in mic and speak through the car speakers)
SD Slot
USB port (hook up any MP3 player or ipod)
4 x 65w power (Very loud system)
MP3 disc playback & DIVX player
2 RCA ports
You can plug in a reversing camera (not included - it is about £10 from ebay)
I will also include the Toyota ISO wiring harness needed to connect it up to your car.
The unit is just over 3 months old now, no faults or marks, it is perfect. Reason for sale is that I really need the money
Price is £165 if collected or £185 delivered by secure insured courier such as DHL .
I paid £230 for the unit imported from Japan including import tax, then £10 ISO lead harness from Halfords. Still has 9 months warranty with eonon.
(p.s. ignore the marked plastic on the side that was a failed attempt of filling the gap on a Corolla - it is not part of the headunit - headunit is standard double din size)
Here is the full spec:
- ISO 2 DIN Size
- Fully Touch Screen
- Screen Size: 7 Inch
- Fully Motorized Slide Down Control Panel
- Control Panel Night Illumination Function
- Power Supply: DC 12V, range from DC 10.8 to 16.0V
- Max Working Current: 10A
- Compatible Format: MP4/DIVX/DVD/VCD/MP3/CD/CD-RW/JPEG
- RCA Video 1 Output/Video 2 Output/CAM input / CDC Video Input /AUX Video 1 input
- RCA audio FR/FL/RR/RL output and AUX Audio R/L Input
- Built-in Microphone in the control panel
- 1×TV Antenna Input
- 1×Radio Antenna Input
- Built-In USB Port/SD Slot
- Built in amplifier FR/FL/RR/RL 4-Channel Audio Output
- 4×65W Surround Stereo
- Image Brightness /Contrast/ Color /Saturation adjustable
- Effect Compensation: POP ROCK CLASS
- Resolution: 480×RGB×234
- TV system: PAL/NTSC
- DVD OSD Language: English/ Italian/German/Spanish/French/Portuguese/Latin
- Audio/ Subtitle Language: English/Chinese/German/Spanish/French/Portuguese/Italian/Latin
- Built-in Radio Tuner (30 Preset Stations)
- FM(3×6)87.5-108MHz( Europe ), Increment 0.05MHz
- AM(2×6)522-1620KHz, Increment: 9 KHz
- Under Radio model, can select Europe/USA radio frequency
- Built-In RDS Radio Receiver Function
- Built-In LCD Clock Display Function
- Auto-memory Function
- Gross Weight: 3.6kg
- Net Weight: 2.7kg
- Install Size:180(L)×163(W)×100(H)mm
- Package Size : 275 (L) × 270 (W) × 185 (H) mm
Accessories:
- 1×Remote Controller ( Battery inside)
- 1×Power Cable
- 1×Antenna
- 1×USB Cable
- 1x ISO Toyota Lead
Please email me or post here if interested cheers :thumbs:
