Evening all,
Recently moved out to NZ from the UK and acquired an imported Japanese 1996 Toyota Sprinter Carib Z-Touring 4WD (1.8 engine, auto). It's basically a Corolla in a push-up bra, and goes pretty nicely. Unfortunately, I have no manual, and even if I did, it would be in Japanese.
One thing that is stumping me is the dashboard compass - this is an LCD affair, labelled "Field Monitor", which gives you the temperature, a compass, and a pretty poor guess at the what the weather is doing.
The compass is about 60 degrees out, and I can't work out how to calibrate it. Next to the Field Monitor is a button saying "Compass Adjust" - if you press this once, the display starts to flash, press it again and it stops flashing. It doesn't seem to behave any differently while flashing (still changes as the car turns), and I can't see that any of the other buttons or dials in the car affect it at all.
Does anyone know how to set this compass, or failing that, how the compasses are set up in Toyotas of the same era?
Cheers,
Alex
(ex of York)
