Help - Search - Members - Calendar
Full Version: Crown 1989 Carburator Help
Toyota Owners Club - Toyota Forum > Toyota Forums > Classic Toyota
rod_tienzo
I have problems with y carburator.. I was wondering if a 4k carburator will be ok to replace a original crown carburator 2.8l super saloon.. does anybody have a diagram for the carburator of crown so maybe i can rebuild it.. i triedbut seemed to get lost for the engine wont start? Help!!
Leeky
Very little info on the carbed 5M, have you considerd getting a Supra MA61 head from a junk yard and converting to EFI?
rod_tienzo
QUOTE (Leeky @ Mar 19 2009, 10:04 PM) *
but if i use a efi .. i think i need a computer box to control it?
Leeky
Yes you will need an ECU. But 5M Ecu's are worthless so you should be able to get one cheap. I threw one out the other day actually.
The late MA61 head will also give you 18 valves instead of your current 12. So quite a bit more power.
rod_tienzo
QUOTE (Leeky @ Mar 20 2009, 09:43 AM) *
Thanks for the tip.. Ill try look out..
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
