Strange Led Taillights Probs
OneKiwi
Heres my prob:
My RHS works fine
upper for daylights/running lights
middle 2 for indicators
lower and upper for break lights
LHS all works fine but when I brake the upper daylights/running lights turn off when the lower brake lights are on
got any thoughts or heard of this before
is a way of reprograming? rewiring them?
Heres a short film of the taillights
http://s30.photobucket.com/albums/c338/sim...nt=MOV04575.flv
Heres my prob:
My RHS works fine
Do the front daylight/ running lights stay lit when you brake?
Ill see if I can check that out today.. I don't think they turn off
If the daylight/running lights at the front go out when you brake then the most likely cause would be a wiring fault but on the other hand if the front dont go out then the fault is with the rear light unit (internal short circuit) Do you have a spare unit to try?
nope no spare unit... ive been trying to find one or someone that could build one, no luch as yet.
Remove the left hand tailight and plug it into the right hand side wiring. If the same happens the fault is with the tailight and not the wiring. If it is faulty are the tailights over a year old? If not contact the seller or manufacturer to get the faulty one replaced.
