Wiring Diagram Tuningbox Cable?
Marsl1970
I'm looking for the wiring diagram of the cable thats's fitted between the tuningbox and the commonrail connectors.
I'd at least like to know which connection of the common rail connector are used to feed the tuningbox.
Reason: I've a cable however it came with seperate feeding wires. I know there is cables out there that provided the feeding to the tuningbox by taking the power for the 6-pin common rail plug. Alas I do not know which pin to take...
Pictures of a cable with clear view on the cables and colors (including the connector that goes in the tuning box are also welcome, as with these I can figure it out as well (if the cables and colors are good visible also in the powerbox connector...)
Thanks for your feedback/replies
Cannot help with your current problem but I am thinking of going the powerbox route and wondered which one you have, which engine etc and if you could keep me informed of how it performs?
David
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
