Hidden Words On Windscreen
Just washed car for 1st time. Found when you wiped the windscreen at bottom on drivers side, you can see the writting from the factory they must have used for easy product i.d. Not too sure what it all says but keep an eye out next time you wipe screen incase it tells you next weeks lottery numbers. :P
Totally pointless info but there you go...
:help: Good question!
Ive got 4 numbers i think, only shows up first thing in the morning. 8568 or something :s
When cars are removed from the boat the windscreens are covered with various stock numbers and Vin numbers etc.. Glass is porous so even when the chalk has been removed it can still be seen..
Steve
