Rav 4 D4d Noise Please Help
ivecoman
hi everyone i,m brand new to this i,d like to ask ye all for help with a problem i have on a o3 rav 4 d4d. at idle there seems to be a vibration in the car , you can feel it in the steering wheel, engine seems to be running rough also a couple of times for a split second while driving i feel i loose power, i,m wondering do i have a problem in the high presure fuel pump or could it be the dmf fly wheel. i dont seem to have any problem with the clutch but while driving more so in top gear if i let of the throttle and then press it again i get a vibration like a loose exhaust but i checked all and there fine. many thanks to you all peter from ireland
hi Ivecoman
check with:
-EGR valve (carbon deposits);
- Fuesl injectors jet spray.
Cheers/Igor
