Carina E
etph
The last time i changed a head light bulb was in a Ford Orion and it took 1 min.
:wacko: I affraid the Toyota Carina E took 45 mins, I had to remove the head light, indicater, grill and one of the horns. Might have been quicker to remove the Battery but then i would have had to set the clock and radio up again!
What??? :blink::blink::blink:
Are U serious?
It's very easy job, I did it in the middle of a dark road, so it is piece of cake...
Cheers
Coyote from BA
Argentina
PD: later I'll tell everyone where I've been these weeks.... ;)
Thank you for your reply
Hi i did wonder after, that if it did not have headlight leveling on it might have been easier to get to. Possibily the design you have may be layed out differently under the bonnet (hood) Also now i have done it once i should not need to remove the grill and horn, i did these two jobs to see what was holding the bottom part of the head light on.
On the car i have you would need very small hands to be able to change the bulb.
About 2 minutes to change it, with the normal fitted lights
With the J. Morette lights (double round headlights) about 3 minutes
