2001 Roadster Radio Facia Panel
corollags
Hey Guys!
I have done a search but all the posts that contain anything to do with it are so old that the links no longer work!
I have just bought a 2001 MR2 Roadster and the Sony factory installed head unit wont work. Im looking to change it for a single DIN unit.
The only facias I can find to do this seem to be listed as 2002>. Does anyone know if this will work or weather there is a seperate one for the 2001 model?
Also Im looking to get a facia which has a blanking panel to cover the 2nd DIN as I have a Scangauge unit to fit into the gap.
Many thanks!
Adam
ISO leads, saves you cutting the loom as it's plug n play...
http://shop.ebay.co.uk/?_from=R40&_trk...kw=mr2+iso+lead
Facia adaptors...
http://shop.ebay.co.uk/items/_W0QQ_dmptZUK...1&_osacat=0
EDIT..
From what I've read once fitted you may find that the plastic trim ring around your headunit won't fit, it can be tricky but give it a good wiggle etc, if it doesn't fit you will need to buy the one from a 2003 roadster.
I don't know the in's and outs as I had no problems with mine.. but then mine is a 2005 model.. part number seems to be... 55423 - 17040 : Surrounding trim
