Celica Gen 6 Electric Aerial.
Big E
Hi all, Today my aerial will only go down when I help it along.
Does this mean I need a new one. The motor is still running (you can hear it trying to lower the aerial.
Is there a nut loose or is this an indication that I need a new one.
Any help before I strip the back out tomorrow would be great.
Cheers
Big E.
the plastic threaded cord inside the ariel fails - ie bits snap off over time and jam the cogs that drive it, new mast at toyota £45 inc fitting.
Hi GT4 Booster... I wish we had a direct contact as you seem to have every answer.... Thanks.
Is it just the aerial that need replacing or do I have to trace it back to the front of the car behind the radio.
ie: Do I just remove the old and replace with new or is it more drastic..
Cheers
Big E
you need a new mast , strip out the boot area on ariel side to gain acess . id let toyota do it as trimming it to stop at the correct position can be a pain. its all in the boot mate no need to go front end.
Thanks... I will have to book it in... Cheers.
sooner you sent me £50 - lol
