Celica Gen 6 Headlight Main Lights & Fogs
Big E
Hi all, (UK Spec Celica gen 6 1998)
Just driving back from the juice station and I thought it was dark.
Pulled over to find that my side lights are working but my main driving lights and fogs are not working.
All rear lights seem to be ok.
My main beam works but thats no good..
I hope its a fuse & if so does anybody know which one it is.
UPDATE:::::
I have checked all the fuses and they are fine. I have checked the relay and its clicking.... So tomorrow I will check the contacts on the stalk..... Fingers crossed..
UPDATE 2::::::::
Found out that I had no negative going to the front lights.....
Found an old repair that was a loose wire.
Took 1 hour to locate but saved me £70 plus vat.....
Cheers
Big E
  • 3 years later...
hi ive got the same problem sides and fogs work but dipped beam doesent it does work with full beam though any ideas?
thanks
look for earth straps going to the wings , loosen connections , clean and re tighten .
