Gt4 Brakes On A Celica Gt
jamesst202
Hey can any one help i have a imported celica st202 with superstrut suspension and have been offer cheap calipers from a gt4 to uprate to bigger brakes, does anyone know if they are a direct replacement? i know the suspemsipn sety up is the same but not sure about the hubs and if the bolts will line up, thanks
unsure mate, its possible that they will fit its normaly the calliper that wont clear the gt4 disc (not enough radius) even if that is the case you should be able to swap for gt4 hubs.
