Celica Gen 6 Head Light Order - Help
Big E
Hi again all,
Can somebody please explain the illuminace sequence of headlights for the UK spec Gen 6 should be.
ie: First turn outer side lights etc.
I am trying to work out if the relay has broken and after a couple of phone calls I seem to be going backwards.
I have located the relay & all the fuses are intact.
I am trying to find out if its the relay or the stalk.
I have side lights when the stalk is turned but no outer driving lights or fog lights.
Even if you can only help on the problem a little bit...feel free to pitch in your advice.
Many thanks all
Big E.
