Toyota Corolla Fuel Pump Problem.
evkolos
Hello,
I have a 2001 Toyota Alex (corolla runx) 1.5 v-vti.
My problem began a year ago, the car couldn’t start at the first turn of the key, I had to try two or three times to get it started. The last couple of days it doesn’t start at all. I have checked everything, flow meter, sparks, etc but it didn’t work and then I sprayed some injection spray in to the throttle and it started immediately, so obviously there is something wrong with the fuel supply. I think I will replace the fuel filter and then the fuel pump.
Anyone had the same problem before? Any ideas?
Thank you.
