Gen 5 Abs Speed Sensor Location
brownyboy
Hi
I have the ABS light always on problem. Started as just coming on every now and again but now its on all the time. I have had a go at jumping the terminals in the diagnostics port and got 2 flashes then 1 flash. So I know its the o/s ABS sensor which is the problem. I tried to reset the codes by pumping the brake pedal quickly while jumped but nothing happened.
Anyway does anyone have a link to or a pic of the location of the sensor. I phoned up toyota today and they want £135+VAT just for the part so i want to see exactly what it is.
Then at some point i will remove the front discs and see what the problem is before i splash the cash.
Cheers
Mark
