2000 Prius Screen Mulfunction
charilaos
Hello to all members,
I have an imported prius 2000 model and the big screen is only illuminated without showing anything atall. So I lost the management of the electric motor, the radio frequencies and so on. My car has no sat nav. Any body else has encounter such problem? May be someone found a cure for it? All help is appreciated. The good think is that the car functions normally.
thank you.
Resources that may be of use to you are http://john1701a.com/ who seems to have owned a MkI Prius, and http://priuschat.com/forums/generation-1-prius-discussion/. The latter may be a good place to start as john1701a posts to priuschat. Hope you can sort it. (I have seen a MkI Prius in Sheffield on a Y plate - but I do not know the owner - so there is another one in Yorkshire!)
thank you kindly but there isnt something there to help solve my problem,as I said my screen is illuminated with a white backlight but there is no illustration of anything.
I dont know if any other member experienced this in his Prius. I wish if there is someone who is breaking for parts his car and is willing to sell me the part.
thank u
sounds like your screen has gone. not much you can do really apart from replace it, your talking a few hundred pounds from toyoa dealer though. but they are quite a common fault though.
