St183 1994 Active Suspension And 4ws
mickydoo
Hi Guy's !!
I need some help/advice on the Active Suspension and 4WS on my recently purchased Celica ST183.
The OSF strut needs replacing,I'm guessing they're diffrent to a non active car and I want to keep the car standard if I can so are they still available,if so where ?? When I press the active button by the gear stick I can hear a clicking sound under the bonnet so it appears its working..
Also the 4WS was working on the car until I put the car in reverse and pressed the button down at the side of the steering column which switches it off,now I can't get it to work again.
There isn't any lights on the dash to say there's a fault. Is there some procedure to reactivate it ??
The car is a 20th Anniversay Edition Jap import with Suede interior and everything appears standard, I've been told its quite a rare car is this the case ?
Any help/advice would be much appreciated !!!!
