Alternator Issues? Wiring? Battery?
Spockoff
Hello fellow toyota owners.
Let me get straight to the point with the symptoms of my problem.
When my car has been warmed up and I rev it past 4000rpm the alternator light comes on and the voltmeter reads over 16 volts. I come off the gas and let the engine idle and then the voltmeter stays at 16 volts for a while and then returns to normal. Any toyota owners have a similar problem to me?
Regards spockoff
turned out to be the voltage regulator inside the alternator. Why dont they keep the regulator seperate any more?
