Avensis 1998 1.8
Rossy
hi all
have fault code p1141 passenger air bag light on,cannot clear code..help...please
Hi Rossy, check wiring connectors under the passenger seat and also to the seat belt pre-tensioners, pull out and then reconnect the plugs just in case there is a bad connection. If the passenger seat has been moved back and forward a lot of times the wiring may be broken also.
Regards Pete.
