Vvtli Lift Bolts
TimmyD190
does any one know the part number for the vvtli lift bolts, and is it recommended to change the rocker cover gasket when changing the lift bolts???
lift bolts (or flange bolts as Toyota call them) are 90105-06293
The rocker cover gasket can be reused but they can get a bit hard with age & not seal up properly so probably best to fit a new one. part no. is 15338-22010
thank you very much, think ill do the gasket while ive got the cover off. thanks again
