Toyota Ecu Reset With Fuse
OldSkoO1
Can someone confirm the following is correct to reset the ECU without D/C the Battery.
Remove fuse box cover in engine bay, passenger side, UK model
Remove fuse pulling tool
Locate "ECU-B" fuse, normally top left, down 3.
Pull it,
Pump brake to discharge any power store
Leave out for 5 mins for good measure
Replace
Now i've done this, all trip computer calculations, clock / avg. speed etc are reset to 0 but i get no other strange behaviour like rough idling, limited power or window buttons not working correctly.
So, have i fully reset the ECU? As i see there are 2 ECU fuses. I just pulled ECU-B
Thanks,
I usually pull out any that say ECU or EFI. (3 on the supra i think)
You may not notice any rough idling, mine doesnt run any different when i reset the ECU.
