morning all,
i have an 02 1.4 petrol corolla with the engine management light on,
error code is p0170 fuel trim bank 1,
anyone any ideas?
direction on this appreciated.
morning all,
anyone any ideas?
air flow meter, temp sensor,lamda
morning all,
anyone any ideas?
thanks for your reply Hogie, i will replace the air flow meter and see if this helps.
If you know any one with a toyota chances are it will be the same just swap it for half hour and take the car for a spin to see does the code come up again. There about 160 quid to buy
  • 14 years later...
Did your ever figure out what was causing it? I've got the same issue, but on a 00/X reg.
